Low Poly Human Head Tutorial
Postby weswes » Tue Nov 01, 2016 3:06 pm
So I have been playing with voxel merge properties and have discovered a simple and fast method of making nice low polygon meshes with Curvy3d, like the human head mesh posted above.
This began with two simple lathes. One for skull and the other for the jaw. Notice the low resolution for both. These are tri polygon meshes fyi.
front view shaded
^^very unpretty and non-head like.
Now I group the lathes like so.
Then under "Mesh" in the menu bar I use Fit To>>Child Object (Inflate)
Then do the same process in the opposite by flipping the heiarchy like so.
Here is what it looks like. Not nice. All those extra polys in the middle. Thats why we voxel merge it. But first!
*Go back to "Mesh" in the menu bar and select "Voxel Merge Properties" and change it to .1
*Now Select the Group in the Group Panel and Voxel Merge the Group.
^^ Nice and tidy mesh. You can now adjust this mesh in Blender and easily implement it for game development. I recommend using the "remesh" property in Blender.
Some Tips....
If you are getting too many tris with ".1" then adjust the voxel merge property to a greater than ".1"
Mirroring your mesh over the Y axis is also useful to create shapes after you voxel merge your lathes.
Re: Low Poly Human Head Tutorial
Postby Simon » Wed Nov 02, 2016 12:45 pm
Cool to see these tools working in low-poly, I usually have 10,000's of tris. Thanks.
Postby weswes » Wed Nov 02, 2016 8:27 pm
Simon wrote:Cool to see these tools working in low-poly, I usually have 10,000's of tris. Thanks.
there are some other polygons that occur through other shapes. ill show you.
this is with the line tool
https://www.youtube.com/watch?v=z4aYzqedfu0
Postby Simon » Wed Nov 02, 2016 11:10 pm
Cool crystal and prism shapes.
Return to Tutorials
Users browsing this forum: No registered users and 5 guests
