Hot Keys
Hot Keys
Postby Simon » Tue Aug 06, 2013 9:46 pm
Work in progress... If you know any missing shortcuts please let me know
File
Open... Ctrl+O
Edit
Undo Ctrl+Z
Cut Ctrl+X
Copy Ctrl+C
Paste Ctrl+V
Paste Mirrored Ctrl+L
Deselect SPACE
Select Previous PageUp
Select Next PageDown
Delete Delete
View
Quick Hide Panels TAB
Fullscreen F2
Frame Selected F
Frame All Shift+F
Wireframe A
Overlay Backdrop F9
Rotate View Arrow Keys
Orbit Tool Hold Alt + Left Mouse Drag
Orbit Tool Snap to Orthogonal Hold Alt + Left Mouse Drag + Press Shift
Toggle Layers Panel F6
(Other F-Keys toggle panels but are subject to change)
Object
Paste Object Properties Ctrl+D
Paste Material Ctrl+F
Lathe Symmetry M
Hide H
Curve
Smooth S
Smooth More Ctrl+S
Mesh
Smooth S
Relax Ctrl+R
Polish Shift+R
Convert to Normal Mesh K
Convert to Adaptive Subdivision Mesh J
Texture
UV Relax Shift+T
Help
Help Contents F1
Tools
Select Q
Move W
Rotate E
Scale R
Soft Move T
(There are a few more Tool keys that rotate sets of tools, but these are not in frequent use and may be discontinued)
Holding Alt and Shift swaps to similar Tools for use with Left Mouse Button.
With a Sculpting Tool selected:
* Set Tool Size Ctrl+Drag Left Mouse Button
* Swap Tool: Add/Sub Inflate/Deflate \
With Brushes and Sculpting Tools
* Swap to Smooth Tool Shift (With appropriate tool for Sculpt/Texture/Surface painting)
* Press 1,2,3,4,5,6,7,8,9,0 to set Tool Intensity from 0 to 100%
Selection
Holding Shift while dragging with the Select Tool (default Right Mouse) adds to multi selection in 3D views and Groups Panel.
Holding Alt while dragging with the Select Tool subtracts to multi selection in 3D views and Groups Panel.
Groups Panel
Drag the left mouse over the 'eye' or 'freeze' icons of several objects to hide/show freeze/unfreeze multiple at once.
Number Entry
Right click on a slider or number to type in a new value.
Smart Backdrops
The set of keyboard shortcuts for this feature is given in the help below:
Smart Backdrops
Postby sculptor » Wed Aug 07, 2013 3:28 am
thanks for the list
a hotkey that i would find useful would be one to 'reset all views' as i seem to need that command a lot
when working in the perspective window
Re:
Postby Midnight Carnival » Thu Nov 28, 2019 3:46 am
sculptor wrote:
'reset all views'
This^
Midnight Carnival
Re: Hot Keys
Postby Simon » Fri Nov 29, 2019 2:27 pm
Added Fullscreen F2
