My proposals for Curvy 3D 4.0
Re: My proposals for Curvy 3D 4.0
Postby Eric1223 » Mon Mar 12, 2018 6:02 am
Is it possible to make all of the textures (bump map, higlights color, highlight, etc) to be combined into 1 the base texture? I know of couple of 2d apps that read .obj files, but they do not have any lighting. Because of that, things like bump maps wont work. I figure the next best thing is to combine all of those into 1 texture so it looks the same as it does in curvy.
Eric1223
Postby Funken » Mon Mar 12, 2018 9:19 pm
Quick Access Bar
Maybe you want to integrate a kind of quick access bar like there is in Word or Excel? This could hold the most-used functions, like New Document, Undo, and so on.
‎Fog in viewport
Fog fades distant objects out so there is a better perception of depth on a 2D monitor.
‎Curve primitives
So, we already have some basic shape primitives like Cube. What about Curve primitives like line, circle, spiral, helix, profiles?
Curve presets browser
Let's the user choose from different curve presets. This could be differently shaped spirals, different profiles and so on.
-best wishes, Funken
Funken
Postby Simon » Mon Mar 12, 2018 10:23 pm
@Eric I guess you mean Baking the lighting into the texture. I'll put it in the wishlist. In the meantime there are several programs you can use that will do this function for you from exported OBJ files. I think XNormal does it for example.
Quick Access Bar YES or something similar. With the new UI comes great flexibility, so it will be easy to try out different bars and shortcuts and see what works well. At the moment I'm planning a thin toolbar down the left to access tools and panels, and another thin toolbar along the top for tool/primitive options. The options one can become a larger panel (like 3.0 Curvy) if you Drag it off the top or Dock it on the sides instead.
‎Fog in viewport YES I often add this as a post-fx but there is no reason it can't simple be another option.
‎Curve primitives YES The existing system of Redraws and Rulers is a bit clunky when all you want is a simple shape. I think this may as well be a simple folder full of SVG shapes. That way you can add/share your own and Curvy can ship with a large number of useful shapes. To draw you would just drag out a size and the curve would appear. More complex shapes would require some parameters and would probably a short script to generate them instead of SVG - so that's more of a wishlist item. I would use this a lot - especially for the really simple stuff like circle, hemicircle, rectangle.
Curve presets browser YES Even if it is just a icon by a name in a dropdown, but I think I can do better.
Postby Funken » Mon Mar 19, 2018 8:38 pm
MODELING
Resolution slider for primitives
Primitives are always at the same resolution when being created. This should be altered so the user can adjust the resolution of primitives. On one hand please think of low-poly work where only very rough models are needed or just because of artistic reasons. On the other hand, higher resolved models are a better start for detailed and high-res sculpting.
Properties for primitives
Instead of having always the exact same primitives when being created extra primitive properties would be welcomed since they would allow for a much wider range of primitives. So, a simple cube could become a rounded crate, a cone could become a 4-sided pyramid, a cylinder could become a tube, and so on. Properties for primitives would open a up a whole new world how a user could start a project.
Curve filters
At the moment, we have the Smooth function to “filter” curves, to make them smoother. I’d like to have more filters that can change the appearance of curves.
Closed curves
Please include an option to automatically close open curves. They could provide as rail curves to sweep profiles along their path in a ring-like matter.
Offset curves
Copies and extrudes a curve along its normals.
New curve type: 3D curves
Currently it is only possible to draw curves on a given, flat drawing plane that corresponds to the planes of the coordinate system. This means that curves are and always will be flat and in 2D. It would be great if you could also create "3D curves" that can run randomly in space. This type of curve could use the screen space as a drawing layer. Whenever you rotate the view, the drawing plane also moves. In this way, 3D curves could be drawn.
New curve type: Splines
Seriously, splines or curves with control points would make a lot easier. They are ideal for drawing complex shapes by just dropping a few control points here and there and then pushing and pulling them to get exactly the shape you're looking for. No more fiddling with Smooth and Move. Splines are practical for complex, organic, but also for hard surface modelling work.
Convert curve to spline
With the introduction of splines, it should be possible to convert freehand curves into splines.
Weighted curves
By giving the control points extra properties like strength the user can make spline curves smoother or harder at certain locations.
Curve projections
A curve is projected onto an object. The curve adapts exactly to the curvature of the object.
Intersection to curve
Curve duplication
Simpler method of copying and arranging a curve several times.
Instant mirror for curves
You may also want to implement a simple method for mirroring curves along a certain axis.
Curve cage deform
Curve interconnections
Connects the ends of two given curves in a smooth and tangential way by generating an interconnection curve.
Connected drawing of curves
Imagine a curve you just drew but you want to extend it. Curvy 3D should allow the user to extend it just by drawing a second curve near on of the ends of the first curve. The ends of both the first and the second curve then automatically snap together forming a single new curve of desired length and shaped.
Drawing curves on objects
This picture shows an example how curves can also be drawn directly on objects in the program 3D-Coat. The curves mimic the curvature of the object. Although the function would be similar to "Projected Curves", the user would have more control over the exact shape of a curve.
Curve generator
This could be a great extension for curve presets. Maybe you want to include a little generator that makes randomly shaped curves based on a few settings to provide for curves like lightnings, tree branches, fractal-like structures and similar.
Rebuild command for standard curves and splines
Very useful for both freehand curves and splines. For splines, of course, the amount and distribution of their control points is changed and recalculated. It can also be great for freehand curves since Smooth smooths every part of a curve in the same way, but maybe you want some parts to be smoother than others. A freehand curve rebuild command might be able to better calculate the curvature.
Sculpt to curve
The brush snaps on a curve lying on an object. In this way, particularly soft brush strokes are possible. Also for hard-surface-sculpts such a mode would be very helpful, e.g. to create hard edges.
Extrude to curve
Works similar to the previous function, but instead of sculpting you extrude along a curve. So you can also create material that protrudes from an object.
Stamp mode
The stamp mode makes it possible to paint individual brush swabs.
Brush tips
You can already adjust brushes using a falloff. But with custom brush tips based on images, you'd have a lot more options.
Instances
Creates resource-saving instances of objects. Instances cannot be edited themselves, but they adapt to changes to the original object immediately.
Random scatter tool
Randomly distributes all objects in a scene or all selected objects.
Remeshing brush
2D cage deform
This looks incredibly useful. A simple flat “cage” that can be altered in shape to deform and warp its underlying mesh object.
Please also consider this video: https://www.youtube.com/watch?v=7g4FhESB31M
3D deformers for objects
With 3D deformers like Twist, Bend, Shear, Stretch, Warp and similar it would be possible to manipulate objects in a simple but very complex way.
Funken
MASKING
Curve to mask
Instead of just painting masks, it should also be possible to create masks from curves.
Backface culling for mask tool
When creating a mask, the program does not differentiate between front and back. With such a feature, Curvy would mask only the user-facing front side.
Mask sharpening
A sharpening function for masks.
Auto-voxel merge when applying a mask
Masks can only be used if the object is no longer based on curves but on a voxel mesh. A function that makes it possible to automatically convert the object into voxels when creating a mask would be useful.
Local transform based on mask
”Remove mask” option for Mask menu
Masks can already be removed, but such a function would clearly be suitable for beginners as well.
Mask sets
A way to save and reuse already saved masks.
Funken
RENDERING
Better alpha setting
Dimmed curves
Curves or parts of curves behind objects are faded out to a certain extent to create a better depth impression.
Flat shading
PBR shading of objects
It would be great if Curvy would support Physically Based Rendering. PBR is a great way to quickly and easily add high quality looking materials to objects.
HDR viewport background
A necessity to be able to use PBR fully in the viewport.
Different color models for color picker
More color models for the color picker would be welcome, like HSL, RGB, and so on.
Auto-update for imported textures
If you have imported textures, the program should always react to external changes and reload the edited textures itself and automatically.
Funken
Postby Funken » Mon Mar 19, 2018 8:41 pm
MISC
Better redrawing performance for objects
The example shows a comparison. If an object is moved to its underlying curve, the object jumps back and forth because the rendering performance is poor. If you move the object itself, the rendering performance is flawless. Maybe it is possible to improve the rendering speed in the next version.
Better performance for some brushes
Certain brushes, especially large ones, have poor drawing performance. This results in choppy strokes, distorted geometry, and a generally slow workflow, which in turn affects creativity negatively.
Better handling of large numbers in UI
Particularly large numbers or data can exceed the width of text fields. This should be adapted for the next version of Curvy 3D.
Explorer thumbnail extension for Curvy 3D files
This would be a Windows add-on that makes the Windows Explorer display a preview of Curvy files.
Collision detection
Simple collision detection could considerably simplify the composition of a scene containing many objects.
Curvy 3D forgets last settings
Every time I restart Curvy, the program forgets certain settings I made earlier. It would be nice if the program would consider all settings adjusted by the user, e.g. hiding the grid.
Image upload to forum
Many threads in this forum have lost all their embedded images. The reason for this is that their image hosters went offline, or because they simply deleted the images. This is a pity, as many threads are no longer usable in this way. A lot of useful information was lost in this way, e. g. tutorials. I think it would be better to host all embedded images on the forum server itself.
Funken
Postby Funken » Mon Mar 19, 2018 8:44 pm
UI/UX
Open as readable only
Another new file management feature. This makes it possible to open Curvy files in read-only access.
New toolbox organization
The division of the first icon group into navigation and manipulation makes more sense to me. What do you think about that?
Preview for Straighten Curve Segment tool
All curve editing tools like Trim and Redraw have a preview where you can see the brushstroke. This should also be possible for the "Ruler" tool.
Preview for Inflate Image
A preview for "Inflate Image". Since the function is very complex, it is cumbersome just for minor adjustments to open it up.
Rename in objects panel
This function would speed up the workflow.
Folders/groups for objects panel
This is a must, I think. This would make it much easier to organize complex scenes.
Resolution display in percent
Brush palette and settings
A toolbar with advanced brush settings would be very welcome. The example image shows a screenshot of 3D-Coat.
Snapping for rotation
I suggest a snapping mode for the Rotate tool. The Shift key could lock at 45° and the key combination Shift-Alt at 15° (or so).
Video tooltips
Many programs now offer video tooltips that eliminate the need for long and tedious text explanations. Maybe a good idea for Curvy 3D, too?
Highlight navigation buttons in viewport when used
When using the navigation tools via shortcuts, the corresponding icons in the viewport should light up. This would give the user more feedback from the user interface, which would be particularly advantageous for beginners.
Pan icon in viewport
The viewport already has the navigation tools Rotate and Zoom. It may also be a good idea to add the Move tool here.
Zoom on active object / group / all
A useful set of zoom modes.
Rendering styles icons in viewport
A set of different rendering modes as found in most 3D programs.
Curves only icon in viewport
Hides everything except curves. Makes it possible to customize complex scenes based mainly on curves.
Single / quad view icons in viewport
Icons that allow the user to quickly switch between one-window and four-window workspace.
Panel settings
It should be possible to customize settings for certain panels. I could imagine a kind of cogwheel icon, via which the user can directly access panel-related settings.
More tooltips
Some functions do not have tooltips, e.g. "Bevel settings".
More import formats for Inflate Image
Currently, the "Inflate Image" function can only import images in BMP format. This is very limited, and should be extended for more formats. I suggest the formats .png, .jpg, .tif, maybe also .hdr and .exr.
Curve import/export
The base of Curvy are still the curves themselves. Since you will be able to import curves in the next version, it would be great if you could also export curves. I suggest the formats .ai, .svg, .dxf and .pdf.
Beginner/Pro mode
You mentioned several times that you want to keep the Curvy 3D user interface simple. Then how about one mode for beginners and one for professionals? The mode for professionals would provide all functions, but the mode for beginners would only provide the most basic functions. Once a user has become familiar with the program, he could quickly switch to professional mode.
Funken
Postby Simon » Mon Mar 19, 2018 9:41 pm
Wow :D Thank you for the great feature list! Looking down it is mostly YES + WISHLIST and a couple of DONE.
I'll be cracking on with the UI for the next couple of weeks, but I can't wait to get implimenting these. A lot of them are mainly UI work, the underlying math/geometry is trivial - so if I can streamline adding new UI that will help.
Just a couple of comments:
If you turn on the "Fog" option you get a smooth alpha bar (this should be made more obvious)
You can group items by dragging the names in Groups Panel, and close a group by right clicking (but Groups needs some work to be easier to use)
Mask sharpening is in the Mask menu, along with other effects that I rarely use because I forget them.
If you turn off the grid you draw in screenspace (and can even rotate the view with arrows while drawing). The easist way to make a 3D curve is to draw it once, then use the Redraw Curve tool to draw it from another angle - it will combine the two curves to make the best 3D approximation of both.
You can "Mirror Clone" to make a mirrored copy of a curve.
We had instances in a Beta of 3.0, but it got too complicated (With editable Instances). Your method of Non-Editable Instances is much cleaner and simpler - useful :)
Postby Funken » Tue Mar 20, 2018 10:29 pm
"Mirror Clone" - I can't believe I missed this. :-) Thanks, Simon.
Regarding grouping: The current implementation feels more like parenting than grouping. In particular, that there are no folders or "null objects" that could be superordinated to other items.
Regarding alpha: It should indeed be made clearer that full alpha is dependent on the Fog setting. I also find the name Fog somewhat misleading, since it is nothing more than transparency?
Funken
Postby Simon » Tue Mar 20, 2018 11:17 pm
I'm really hoping the new UI will make things like "Mirror Clone" easier to stumble upon and learn how they work. Tips with images or videos may well be handy.
I've been thinking about scene organisation. Logically it is not like layers in a 2D paint program, but rather it is a collection of groups, or trees, that don't have any fixed order. It is a nightmare when you have 100's of little objects in a scene (can't manage them effectively as anythign other than a huge group). And you quickly get lots of objects with rather undescriptive names. I guess it should be more like a file browser, with folders and sorting, and previews. Might be interesting to sort the list by size, or by position in an axis, and highlight the object in the 3D view as you mouseover it in the list. could even popup a preview window with the object centred and the rest of the scene faded out to be absolutely clear what you were selecting. In any case it should be no harder to use than a file browser - and perhaps easier than that.
The only reason there is a "Fog" setting is that you can load a texture with alpha onto an object, and you need to let the renderer know to render it with alpha (even though it's diffuse colour might have 100% alpha). It is rather a special case and 99% of the time it would be simpler just to turn on the alpha blending renderer as soon as the diffuse alpha is 99% or less. I'll make that the default behaviour. Just to note - sometimes you want an alpha texture without the alpha-blending so you can get a hard edge without a fade out. But again the option should probably be reversed, and "Hard Edge Alpha" should be the option you turn on for that behaviour, and the rest of the time it is soft alpha blending for diffuse colour and textures.
So in practice I use "Fog" when I want to use a Lightmap with an alpha fade out to make smoke trails. But I agree the name is inconsistant with normal usage - especially when I add normal Depth-Fog!
Postby Funken » Wed Mar 21, 2018 4:11 pm
Shift-Click Select / Ctrl-Click Select
Please make it possible to select several objects at once - according to Windows standard. Ctrl-Click selects individual objects - object by object. Shift-Click selects a group of objects at once. This means that with Shift-Click you select the first element and the last element, and all elements in between are selected automatically. Shift-Click select refers in particular to selections in the Object Panel.
Select All with Ctrl-A
This is a very common shortcut to select all visible objects.
Select menu
Perhaps you would like to introduce a dedicated selection menu that contains all selection-related functions?
Scrolling in Groups panel even without any objects in it
This is a kind of shortcoming, but not really a bug I think. So it is possible to scroll with the mouse wheel in the Groups panel, even if there are no objects in it.
Funken
Postby Simon » Wed Mar 21, 2018 8:04 pm
If you click the square in the top left of a view it toggles between 1 and 4 viewports.
Groups menu needs a bit of work. Should be able to fix the scrolling too.
I should gather the selection ideas together. Select All is a good idea. It gets a little complicated in that you can select a parent without selecting its children sometimes. It may be that a separate 'folder' object is helpful in organising things (or it may complicate things! May need to try it out on a big sculpt and see how it feels.)
Certainly the old system of setting up a parent + child pair to run a command on does not work well for me. If you just want a quick command you can simply select the two objects at once - perhaps with the last object selected having priority in the way the command operates.
Postby Simon » Wed Apr 25, 2018 1:04 pm
Getting back into this now - Added the "Better rotation tool handle". Lots more to come :)
Postby Funken » Sun Apr 29, 2018 8:10 am
Excellent work! :mrgreen:
Funken
PreviousNext
