scale individual axes
Postby titti » Sat Oct 17, 2015 1:56 pm
Hi. I installed Curvy 3d v.2 for mac system (10.8.5).
All right well indeed, but I can not scale the object on the individual axes. Why? How is it done?
Thanks
titti
Re: scale individual axes
Postby Simon » Sat Oct 17, 2015 4:52 pm
Hi, in version 2.0 you can use the scale tool at the same time as holding down X, Y, or Z key on the keyboard. This will lock the scaling to each axis.
[[In version 3 you can simply use the coloured handles on the move widget]]
Postby titti » Mon Oct 19, 2015 7:28 am
hi, thanks for the reply. I've tried and tried. Does not work.
titti
Postby Simon » Mon Oct 19, 2015 7:46 am
Sorry to hear that.It is possible that the Mac version has a problem detecting the keys being pressed down while you drag. Unfortunately I no longer have a Mac to test it on.
I know it is a long way roung to scale a model, but you could also export to OBJ, scale the object in Blender, then import it back in.
Postby mykyl » Mon Oct 19, 2015 9:11 pm
Colors paint with the correct shade now but as mentioned no xyz scaling although other keys do work.
