Curvy 3D is Fun, Easy, and Creative
Aartform Curvy 3D is a fast and easy 3D modelling program that lets you create stunning models in minutes. Whether you are a beginner or a professional, you will love the intuitive interface, the powerful sculpting tools, and the realistic rendering options. You can start with simple shapes and then refine them with brushes, inflate, smooth, and twist them into organic forms. You can also paint directly on the models, add textures, and export them to other formats. Aartform Curvy 3D is a fun and creative way to express your imagination in 3D.
Aartform Curvy 3D has many fun features that make it a unique and enjoyable 3D modelling program. Some of them are:
- Sketch-based modelling: You can draw curves on the screen and watch them turn into 3D shapes automatically. You can also sketch on the models to add details and cut holes.
- Image-based modelling: You can import images and use them as references or as textures for your models. You can also trace over images to create 3D shapes from them.
- Boolean operations: You can combine, subtract, or intersect multiple models to create complex shapes. You can also use boolean operations to create hollow models or cutouts.
- Symmetry and mirroring: You can use symmetry and mirroring to create symmetrical models or to duplicate parts of your models. You can also use radial symmetry to create circular patterns or shapes.
- Sculpting and painting: You can use a variety of brushes and tools to sculpt and paint your models. You can also use pressure sensitivity, layers, masks, and blending modes to achieve different effects.
- Rendering and exporting: You can render your models with realistic lighting, shadows, and materials. You can also export your models to other formats, such as OBJ, STL, or PNG, for further editing or printing.
If you are looking for a 3D modelling program that is fun, easy, and creative, then you should try Aartform Curvy 3D. It is a program that lets you create amazing 3D models in minutes, without any hassle or frustration. You can sketch, sculpt, paint, and render your models with simple and intuitive tools. You can also import images, use boolean operations, and apply symmetry and mirroring to create stunning and unique models. Aartform Curvy 3D is the most fun modelling program I have ever used, and I highly recommend it to anyone who wants to unleash their imagination in 3D.
