www.curvy3d.com Forum Index www.curvy3d.com
Software for Artists - Aartform Curvy 3D
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Curvy 3D Home
Features/Screenshots
Forum
Gallery
Download
Order Now
Simple Human
Post new topic   Reply to topic    www.curvy3d.com Forum Index -> Gallery
View previous topic :: View next topic
Author Message
Vanrailey
PostPosted: Tue May 19, 2009 3:41 pm    Post subject: Simple Human Reply with quote
This is just a simple model that I did to test out a workflow. I will try to add an image daily, also hopefully making the models more complex as each one progress, along with adding variety (thus some non organic models).
Each modeling session I do I will sit down with a stop watch (not for speed modeling,... but just because some people may be curious... well I'm curious... Razz ..) Plus, I tend to round up to the nearest 5 mins.
Also, all critiques are greatly appreciated.
PS... sorry for the first lathe model to be backwards.
Back to top
View user's profile Send private message
PostPosted: Tue May 19, 2009 3:58 pm    Post subject: Reply with quote
very impressive
you have a good eye for 3d form.
I am interested to why you need zbrush in the 3rd stage.
Maybe we could ask simon to make some changes so it could be done in curvy ?
Back to top
Vanrailey
PostPosted: Tue May 19, 2009 4:48 pm    Post subject: Reply with quote
Biggest reason I used zbrush in the 3rd step was basically because I'm used to Zbrush 3 functions and sculpting and such. Nothing too big as in this case. It truly wasn't neccessary since the model is a fairly low polycount. But typically I use Z3 for doing the fine detail with like a million+ polycount in some cases.
But just to say, if I tried to do the same type of model in Zbrush, it would have took me at least twice the time. Because the Zspheres can only do so much when trying to set a base mesh for modeling. Even now I typically run into alot of problems zspheres.
Although on that note, Curvy's mesh combining seems pretty solid, flexible, and fast. One of the biggest time consuming, irritable, things I didn't like to do in modeling was when I needed to combine meshes. I made several trial programs crash when I tried to boolean to many meshes together ( silo and lightwave). And a function in Zbrush 3 (unified skin) in most cases gave me a lot of grief when trying to make one continuious mesh (and I do mean a LOT). But Curvy truly sings in this notion.
Didn't mean for this to be a mouth-full but I'm still increasing my knowledge of Curvy 3D at the moment.
Back to top
PostPosted: Tue May 19, 2009 4:56 pm    Post subject: Reply with quote
Thanks for info
Back to top
PostPosted: Tue May 19, 2009 6:19 pm    Post subject: Reply with quote
This is a great experiment with workflow - and I know you have only had the Curvy 2 Beta for a matter of hours!
The overall working timings are brilliant - and hopefully very tempting to other ZBrush users out there.
I look forward to seeing more Smile
Back to top
Display posts from previous:
Post new topic   Reply to topic    www.curvy3d.com Forum Index -> Gallery All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
