WINK from Debugmode - and its FREE
Wink allows you to record desktop action or application windows and create smooth, animated Flash demonstrations from the result, which can be saved in SWF format or as standalone EXE file with integrated playback. Simply press a keyboard key every time you want to capture a frame; when you are finished, you can annotate each frame, using a variety of comment shapes. You can also include Next and GoTo button, allowing the viewer to navigate the animation or jump to specific frames. The frames are then rendered into a smooth Flash animation that can be played in the user`s browser or the standalone EXE file with viewer. Wink is easy to use and lets you create quality Flash demos with no further experience needed.....
http://www.debugmode.com/wink/
Tool for tutorial
- Curvy3D Professional
Wow! This sounds great
. I'll dl it as soon as I get home tonight and check it out!
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
-Rich Cook
-Rich Cook
