I played with the demo a bit and just bought and installed the regular version.
In the demo when I used the lathe tool, I drew a line and a 3d lathe form appeared.
Now, when I use the lathe tool and draw a line, I have the line I just drew in red and a blue line representing the axis. no 3d form.
Lathe problem
I figured out what was wrong (sort of)
I had the demo installed when I installed pro. When I took the demo out nothing showed; not lathes, meshes, imported obj, etc.
I put the demo back in so I could at least use it, then the regular one worked.
I decided I didn't need the demo & pro installed, so I uninstalled demo. Same problem.
I figured uninstalling the demo removed some files necessary for Curvy Pro. Don't really know what.
I reinstalled Pro and it works fine.
Aha - sorry about that. I think if you use the same install path for the demo and the full version - then uninstall the demo - it will accidentally uninstall files needed by the full version.
Reinstalling Full version after uninstalling Demo will fix it.
Thanks for following this up with the solutions it is bound to help other people, and the next version of the demo will be more careful!
Re: Lathe problem
hey i have that same problem i used demo and bought full 2.0. i was unstalled demo while full is on. when i open to create lines and it turn funny just blue line with red dots something. when i read what all of u said. i will do unstall full one and make sure both unstall and hope to install full version to see if it solve the problem.motleyjust wrote:I played with the demo a bit and just bought and installed the regular version.
