New colors UI and icons (For Curvy3D 3.0)
I just bought this cool 3d software this morning, and i have changed some colors in the UI for my needs.
Before extract my file, it's better to save your "GUI.BMP" in other location to go back with the default colors if you don't like my change. The "GUI.BMP" file is located in the main folder of Curvy.
You need to rename my file in "GUI.BMP" to see the change at the next start up of Curvy.
Here the preview:
Here the preview:
- Attachments
- curvy_new_colors_UI.jpg (116.36 KiB) Viewed 98887 times
- GUI.zip
- (71.76 KiB) Downloaded 6455 times
Re: New colors for the UI
Thanks for the palette remix. I like the locked icons in particular.
For 4.0 I'm currently planning a double palette - one dark monochrome, and a lighter colourful one. Still a work in progress.
I made a new one with better colors code for all tools for eye catchy, this not the final version yet:
- Attachments
- GUI_V2.zip
- (70.37 KiB) Downloaded 6509 times
- curvy_new_colors_UI_V2.jpg (203.71 KiB) Viewed 98878 times
There should be a tiny list of pixels in the corner of the GUI image that sets some other default colours around the UI. Should be possible to change the standard blue/grey panel colour if you wanted to as well.
Yes i have found the tiny colors for the text color, i need to test them, for the UI color maybe you can make a preset_UI_colors folder that call the GUI.BMP file or GUI2.BMP, GUI3.BMP following the colors set etc... at starting but need to be save in a user preference file. It's only a idea, you must be busy with the new version.
I have see the new features for the 4.0 version and there was awesome. There will be a "snap to grid" in Curvy ? and for the bevel it's will be cool to have a number enter with the slider like the resolution.
Yes, all work is going to new version now - which will hopefully include support for multiple GUI designs very simply.
4.0 also has more alignment and transform precision - easy type in values and such. I've not needed grid-snap myself, but it is certainly a possibility.
For exact bevel sizes right click on the slider to use a type-in box. Works on all the sliders
Thanks for the right click tip on sliders, i never do that, i need to read the manual more in depth, for the snap to grid its for specific design (like mechanical) maybe it's not suitable for curvy because curvy = freedom modeling with shapes.
Here the GUI V3 version, main change, the main UI color is in gray with some little changes for others colors.
- Attachments
- Curvy_GUI_V3.png (160.63 KiB) Viewed 98854 times
- GUI_V3.zip
- (70.22 KiB) Downloaded 7333 times
Re: New colors for the UI (GUI V3)
Hi Simon thanks to send me the free 4.0 upgrade, i want you ask it is possible to change the icons colors in the UI, as i did with the Curvy 3.0 version, I need to edit the svg files in inkscape to add colors ?
You can either change CurvyIconsV2.svg in Inkscape (and re-export as Icons.png) or directly change Icons.png.
Thanks Simon, i already found the way with inkscape, for the moment i'm in the beginning of the process to add colors in the icons, i have see that Curvy 4.0 still use the GUI.BMP file from Curvy 3.0 for some icons.
I look forward to seeing the results
Re: New colors UI and icons (For Curvy3D 3.0)
I create a new topic for the new colors in Curvy3D 4.0: viewtopic.php?f=47&t=3782
