Using Curvy with Lightwave ?
Does anyone have any experience or recommended workflow for using Curvy with Lightwave, expecially for character or organic work (since 2018 Lightwave has been on the newer LWO3 file format). Any thoughts or suggestions for import/export or workflow appreciated.
Re: Using Curvy with Lightwave ?
Lightwave supports importing OBJ format, which is the main export format from Curvy.
I've found it helpful to "Mesh/Join" groups of objects of the same material to reduce the number of objects you have to deal with in the imported model.
