svg lathes
svg lathes
realized i could use imported svgs as lathes in the beta.
draw a starting line, import svg, delete starting line.
As curvy has no way of guessing your intentions when used this way, you need to do a bit of untwisting (rotate ), move,copy, paste etc.
tip:-
sweet home 3d has great svg export, just draw walls and export them as svgs.
Re: svg lathes
Cool smooth shapes! I use Inkscape for my SVG's, good boolean support.
