Added an Align Ends button that lines up all the ends of your Lathes at the ends. Avoids having to manually tweak the position of the endpoints.
New Point to Point curve drawing mode lets you click a sequence of points and Curvy joins the dots to make a precise shape with straight segments. (Again - saves time compared to using the ruler on a drawn curve, and easier to use than holding Ctrl to make straight segments).
Curve Mirror make a curve symmetrical.
Curve Tools
Re: Curve Tools
Adding live previews to the Curve tools, so you can see the effect of each of the Curve Rulers and find the perfect shape before you finish with the tool.
Also adding some 'after-touch' effects to the Circle rulers so you can change the orientation and size of the circular arc by holding SHIFT rather than having to rely on the automatic sizes Curvy guessed at before.
