Inflate Image ???
Inflate Image ???
If you convert a BMP image into a 3D object, you will end up with a slanted object like this.
- Attachments
- 1594711653_20.jpg (141.25 KiB) Viewed 23169 times
- bbb0001.jpg (54.87 KiB) Viewed 23169 times
Re: Inflate Image ???
Hi, the Bitmap needs to be a 24 bit RGB image saved in BMP format. I think your example is a greyscale 8 or 32 bit image.
It also helps if the size is a multiple of 4.
I solved it by converting even grayscale images to 24-bit BMP images.
