Merging Sculpted Primitives
Hello! I've studied merging sculpted primitives with Weld to Parent, but it doesn't always work. Why?
- Attachments
- Снимок экрана (10).png (814.05 KiB) Viewed 6372 times
- Снимок экрана (11).png (743.77 KiB) Viewed 6372 times
Re: Merging Sculpted Primitives
And another interesting feature when using Voxel Merge Group. I merged curves of 1900, 10,000, and 100,000 tris - the result was meshes with a resolution of 149,000, 37,000, and 86,000 tris, respectively. It’s not clear how they merge like that)).
- Attachments
- 86 000.png (281.45 KiB) Viewed 6369 times
- 37 000.png (492.08 KiB) Viewed 6369 times
- 149 000.png (447.35 KiB) Viewed 6369 times
I think Curvy had problems working out the overlap to weld to parent. In these cases you can cut parts of the meshes out with the lasso tool, Mesh/Join them, and use Mesh/Stitch Holes to join them together.
Voxel Merging will create meshes with a number of triangles proportional to the surface area of the model. You can also change the density by using Mesh/Voxel Merge Properties to choose how big a Voxel is in space.
